(2019) Service Bulletin 1942 Rev A: Approval of GTN 6XX/7XX Software Version 6.62 and Flight Stream 510 Software Version 2.51
PRODUCTS AFFECTED:
GTN 6XX/7XX systems installed using FAA STC SA02019SE-D and EASA STC 10037574 are affected.
CERTIFICATION AUTHORIZATION:
FAA STC SA02019SE-D and EASA STC 10037574 (see Approval section for details)
COMPLIANCE:
Optional: This STC Service Bulletin may be incorporated at the owner’s discretion and is not warranty reimbursable.
PURPOSE:
GTN 6XX/7XX software version 6.62 includes the following:
- New FIS-B Products – Lightning, Turbulence, Cloud Tops, Icing, Graphical AIRMETS includes Current Report List (CRL), and Center Weather Advisory (CWA) includes associated Current Report List (CRL)
- Allow LNAV+V on an LNAV approach that also has published LPV, LP and/or LNAV/VNAV minima
- Implement the range to selected altitude arc on the GTN with the appropriate inputs from the GDU
- Added GTN support for flight data log streaming
- Added G3X certified interface, which is already approved via STC SA01899WI
Flight Stream software version 2.51 includes the following:
- Support for the GPS 175 and GNX 375
- Improvements for flight data logging
