The Garmin Connect™ app Home view offers an intuitive experience with an option to select a focus to help simplify and prioritize the data that is most important to you.
How Do I Edit My Home Page?
Open the Garmin Connect app.
Select Home (bottom left).
Scroll to the bottom of this page.
Select Edit Home.
From here you can enable or disable the options listed in the image below:
Back to top
How Do I Edit What I Have In Focus?
Select Edit Home.
Select Edit in Focus.
Select
to add stats.
Select
to remove stats.
Hold and drag
or
to re-order your stats.
Select Save (top right).
Back to top
How Do I Change My At a Glance Menu?
Select Edit Home.
Select Edit At a Glance.
Select
to add stats.
Select
to remove stats.
Hold and drag
or
Back to top
How Do I Reset My Home Page?
If you would like to reset the focus of your Home page, follow the steps below:
Select Edit Home.
Select Reset Home.
Select a new focus:
Be Healthy: Focuses on Sleep, Body Battery, and Steps.
Stay Active: Focuses on Sleep, Body Battery, and Exercise Trends.
Track my Training: Focuses on Training Readiness and Training Status.
Save to confirm.
Back to top
How Do I Edit the Last 7 Days and Yesterday Sections?
The information displayed on either the Last 7 Days or the Yesterday sections will be based on what is set for both At-a-Glance and In Focus.
Back to top
How Do I Manually Add Data from the Home Page?
Depending on how you have your Home page configured there are short-cut options to manually add in data such as weight, fluid intake, timed activities, and more. For details on how to access these shortcuts, see below:
Manually Adding an Activity:
To add a manual activity recording, you will need to have an activity trends card configured under the In Focus section as shown below. From there, select the + icon to add your manual activity.
Manually Adding Wellness Data:
Manually adding a blood pressure reading, weight, or hydration, is done from the At a Glance section of the home page. Here, you will need to have a measurement active as an At-a-Glance card. Then select the + icon to add a measurement.
Back to top
How Do I Edit the Menu Ribbon on My Home Page?
The menu ribbon located along the bottom of the Home Page can be edited by following these steps:
NOTE: To avoid redundancy, after adding an item list like Workouts, Segments, or Performance Stats as a bottom tab, this item will no longer appear on the side menus in your Connect app.
- Select More from the bottom right corner.
- Select EDIT from the upper right corner.
Select
to add up to three tabs.
Select
to remove tabs.
Hold and drag
or
to re-order your tabs.
Back to top
