Accessing Routes Transferred From the Computer on an Automotive Device
Your automotive device is NOT compatible with routing in BaseCamp™. These devices may appear to take a route without issue however, when navigating the route, an error message may appear. An alternate program to use is MapSource. First download the map to your computer. See Installing Maps to the Computer Using Garmin Express. Then use MapSource to create and transfer routes to your device. The routes must be imported before they can be accessed.
To Access a Transferred Route:
- Touch Tools
- Touch My Data or User Data
- Touch Import Route(s) from File
- Select the routes you would like to import
- Touch Import
The device will now import the selected routes. The routes that were imported can be found in the "Routes" option under "Where To?".
NOTE: When routes are imported to your Garmin device, the route may change due to navigation settings within your device.
