"Lost Tachometer" on a GHP Autopilot
This message appears when the CCU (Reactor or compass ball) fails to get consistent tachometer readings from the engine. If the engines are off and the GHP™ Autopilot is still engaged, this is expected. It is always recommended to disengage the autopilot before turning off the engines.
If the message occurs while the engines are on, make sure the speed source is set to GPS and that the software is current (see related content).
