Installing Music from Deezer to Your D2 Air Series Watch
This FAQ will guide you through the process of loading music from Deezer to the D2 Air and D2 Air X10 watch.
Requirements
The following are requirements to use the Deezer app:
I Meet the Requirements. What's Next?
Select each of the steps below to reveal instructions to initially set up the Deezer app on your watch followed by downloading music to your watch.
Step 1: Setup the Deezer Connect IQ App on the Watch
NOTE: Your watch must be able to connect to a previously connected Wi-Fi network. You will also need your smartphone that is paired to your device through the Garmin Connect app.
  1. From the watch swipe to the Music Playback Controls widget.
  2. If you see a welcome message select the Deezer logo. If so, proceed to step 6. If not, proceed to step 3.
  3. Press and hold the menu button (bottom right) to access the music menu.
  4. Select Music Providers.
  5. Select Deezer.
  6. Return to the Music Widget and select the music note icon.
  7. Select Deezer to manage music.
  8. The watch will attempt to connect to your Wi-Fi network.
  9. Once connected, the watch will display a message to Open Garmin Connect on Phone. Select Next
  10. Acknowledge the message on the phone which will take you to Deezer. Depending on whether you have an account, the login process will be as follows:
    • Existing Deezer users: Enter your login details and select Log In. From here, continue to the last step "Syncing Music to Your Watch".
    • New to Deezer: Tap the Register here link and follow the steps to create your account.
  11. If prompted, enter credit card details to complete the process. Proceed to Step 3
Step 2: Syncing Music to Your Watch
  1. From your Deezer account, create playlists. Saved playlists will display as optional music to sync on your device. For more information see Deezer Support.
  2. From the watch swipe to the Music Playback Controls widget
  3. Select the music icon
  4. Select Deezer
  5. Select My Playlists
  6. Choose playlists you want to sync to your watch.
  7. Exit by swiping back until you see the message "Ready to sync?". Select Yes to begin syncing music.
The amount of time required to sync music will depend on the number of songs being syncing, the speed of the internet the device is connected to and the quality of the Wi-Fi signal.
