Changing the Waypoint Icon and Uploading Custom Images on Alpha 200 Plus or Alpha 300 Series
You can change the icon you use for waypoints on your Alpha® 200 Plus, Alpha® 300, or Alpha® 300i dog tracking handheld to make them more customized.
Icon
- Select Waypoint Manger
- Select the waypoint you want to change
- Select the waypoint's icon
- Use the left and right arrows to view new icons
- Select Waypoint Manager
- Select
- Select Change Photo
- Select the photo you would like to use
Import Image or Icon on to Handheld
- Connect your Alpha 200 Plus or Alpha 300 handheld to a compatible computer
- Open the device as a drive.
- Open GARMIN folder
- Open CustomSymbols folder
- Place your jpg or bmp file in this folder
- JPG is used for photos
- BMP is used for icons
- Safely disconnect the device.
