Navigating a Route in the Earthmate App
Routes that you have created or saved at explore.garmin.com can be synced to the Earthmate® app and used to navigate. Use the instructions below to navigate a route in the app.
Navigating a Route on iPhone®/iPad®
Open the Earthmate app.
Select More.
Select Routes.
Select the desired route.
Touch
Select Navigate.
NOTE: If no inReach® device is actively connected, you will be prompted to use your smartphone's GPS to navigate.
The map will now show a line for the route being traveled, and the following data fields will be displayed below the map:
Distance to Waypoint
Bearing to Route
Speed
Heading
Elevation
Coordinates
If you are not already at the start of the route, the app will navigate in a straight line from the current location to the beginning of the route.
Navigating a Route on Android™
Touch
Select Routes.
Select Navigate.
NOTE: If no inReach device is actively connected, you will be prompted to use your smartphone's GPS to navigate.
Distance to Finish
Bearing to Route
Speed
Heading
Elevation
Coordinates
Android is a trademark of Google LLC.
iPhone, iPad, and Apple are trademarks of Apple Inc., registered in the U.S. and other countries.
