What is the Functional Threshold Power Feature on My Garmin Device?
Functional Threshold Power (FTP) is a key performance marker that can help you guide your efforts, optimize workout intensity, and track changes in your cycling performance over time. It is popularly defined as the level of intensity you can sustain for about an hour. Your compatible Garmin® device can estimate your FTP using advanced analytics to interpret your cycling performance.
Topics
Select a topic below to jump to its content.
Devices With Improved FTP
Many newer Garmin devices can more easily detect FTP with just a paired power meter and an established VO2 max. These do not have a guided test. To determine if your device is compatible, refer to the list below.
Compatible Device List
NOTE: If your watch or cycling computer is not listed below, see the following content to learn how to obtain an FTP reading: What Is a Functional Threshold Power Test?
  • D2™ Air X15 watch
  • D2™ Mach 1 | D2™ Mach 1 Pro watches
  • D2™ Mach 2 watch
  • Descent™ G2 watch
  • Descent™ Mk3 | Descent™ Mk3i watches
  • Edge® 540 Series | Edge® 550 | Edge® 840 Series | Edge® 850 | Edge® 1040 Series | Edge® 1050 | Edge® MTB cycling computers
    • These Edge cycling computers can record FTP with just a power meter but we suggest the inclusion of heart rate. This can be from a traditional strap or a Garmin watch with the ability to broadcast heart rate.
  • Enduro™ 2 watch
  • Enduro™ 3 watch
  • epix™ (Gen 2) - Standard Edition | epix™ (Gen 2) - Sapphire Edition | epix™ (Gen 2) - Porsche Edition watches
  • epix™ Pro (Gen 2) - Standard Edition | epix™ Pro (Gen 2) - Sapphire Edition watches
  • fēnix® 7 - Standard Edition | fēnix® 7 - Solar Edition | fēnix® 7 - Sapphire Solar Edition watches
  • fēnix® 7S - Standard Edition | fēnix® 7S - Solar Edition | fēnix® 7S - Sapphire Solar Edition watches
  • fēnix® 7X - Solar Edition | fēnix® 7X - Sapphire Solar Edition watches
  • fēnix® 7 Pro - Solar Edition | fēnix® 7 Pro - Sapphire Solar Edition watches
  • fēnix® 7S Pro - Solar Edition | fēnix® 7S Pro - Sapphire Solar Edition watches
  • fēnix® 7X Pro - Solar Edition | fēnix® 7X Pro - Sapphire Solar Edition watches
  • fēnix® 8 - AMOLED Edition | fēnix® 8 - Solar Edition watches
  • fēnix® 8 Pro - AMOLED | fēnix® 8 Pro - MicroLED watches
  • fēnix® E watch
  • Forerunner® 570 watch
  • Forerunner® 955 | Forerunner® 955 Solar watches
  • Forerunner® 965 watch
  • Forerunner® 970 watch
  • Instinct® 3 - AMOLED | Instinct® 3 - Solar
  • Instinct® 3 Tactical Edition - AMOLED | Instinct® 3 Tactical Edition - Solar
  • Instinct® Crossover - AMOLED | Instinct® Crossover - AMOLED Tactical Edition
  • MARQ® Adventurer (Gen 2) | MARQ® Athlete (Gen 2) | MARQ® Aviator (Gen 2) | MARQ® Captain (Gen 2) | MARQ® Golfer (Gen 2) watches
  • MARQ® Adventurer (Gen 2) - Damascus Steel Edition | MARQ® Athlete (Gen 2) - Carbon Edition | MARQ® Athlete (Gen 2) - Performance Edition | MARQ® Commander (Gen 2) - Carbon Edition | MARQ® Golfer (Gen 2) - Carbon Edition watches
  • quatix® 7 - Standard Edition | quatix® 7 - Sapphire Edition | quatix® 7X - Solar Edition | quatix® 7 Pro watches
  • quatix® 8 watch
  • tactix® 7 - AMOLED Edition | tactix® 7 - Standard Edition | tactix® 7 - Pro Edition | tactix® 7 - Pro Ballistics Edition watches
  • tactix® 8 - AMOLED | tactix® 8 - Solar watches
  • Venu® 4 watch
  • Venu® X1 watch
Requirements
  • An established Cycling VO2 Max estimate
  • A paired power meter
    • A paired heart rate source from a Garmin watch or an HRM strap can improve the reliability of your estimate.
Back to Topics
Devices With An FTP Test
Other compatible devices that do not have Improved FTP will have a guided FTP test as well as some additional requirements. To determine if your device is compatible, refer to the list below.
  • D2™ Charlie watches
  • D2™ Bravo watches
  • D2™ Delta | D2™ Delta PX | D2™ Delta S watches
  • Descent™ G1 | Descent™ G1 Solar | Descent™ G1 Solar - Ocean Edition watches
  • Descent™ Mk1 watches
  • Descent™ Mk2 | Descent™ Mk2i | Descent™ Mk2S watches
  • Edge® 520 | Edge® 520 Plus cycling computers
  • Edge® 530 cycling computer
  • Edge® 830 cycling computers
  • Edge 820 cycling computer
  • Edge® 1000 cycling computer
  • Edge® 1030 | Edge® 1030 Plus | Edge® 1030 Bontrager cycling computers
  • Enduro™ watch
  • fēnix® 5S | fēnix® 5 | fēnix® 5X watches
  • fēnix® 5S Plus | fēnix® 5 Plus | fēnix® 5X Plus watches
  • fēnix® Chronos watch
  • fēnix® 6 - Standard Edition | fēnix® 6 - Solar Edition | fēnix® 6 - Pro and Sapphire Editions | fēnix® 6 - Pro Solar Edition watches
  • fēnix® 6S - Standard Edition | fēnix® 6S - Solar Edition | fēnix® 6S - Pro and Sapphire Editions | fēnix® 6S - Pro Solar Edition watches
  • fēnix® 6X - Pro and Sapphire Editions | fēnix® 6X - Pro Solar Edition watches
  • Forerunner® 735XT watch
  • Forerunner® 745 watch
  • Forerunner® 935 watch
  • Forerunner® 945 | Forerunner® 945 LTE watches
  • Instinct® 2 - Standard Edition | Instinct® 2 - Camo Edition | Instinct® 2 - Surf Edition | Instinct® 2 - dēzl Edition watches
  • Instinct® 2S - Standard Edition | Instinct® 2S - Camo Edition | Instinct® 2S - Surf Edition watches
  • Instinct® 2 Solar | Instinct® 2 Solar - Tactical Edition | Instinct® 2 Solar - Surf Edition watches
  • Instinct® 2S Solar | Instinct® 2S Solar - Surf Edition watches
  • Instinct® 2X Solar | Instinct® 2X Solar - Tactical Edition watches
  • Instinct® Crossover - Standard Edition | Instinct® Crossover Solar | Instinct® Crossover Solar - Tactical Edition watches
  • quatix® 5 | quatix® 5 Sapphire watch
  • quatix® 6 | quatix® 6 Titanium | quatix® 6X Solar watches
  • tactix® Charlie watch
  • tactix® Delta - Sapphire Edition | tactix® Delta - Solar Edition | tactix® Delta - Solar Edition with Ballistics watches
Requirements
For instructions on performing an FTP Test, refer to your owner's manual. Below is an example of what you can expect from an FTP test:
FTP Test Example
Locate the FTP Test. Refer to your owner's manual for the exact location.
FTP Test Screen On Edge
The device will generate a workout with 7 steps including a warmup. This is an example of what your workout may look like depending on your user stats.
FTP Test Workout Screen
The screenshot on the left shows the warmup step. You can warmup for as little or long as you like and proceed to the next step using the lap key.
FTP Test Edge Screen
Back to Topics
Why Am I Not Getting an Updated FTP Reading?
If you are not getting an updated FTP estimate, make sure that you are meeting the requirements listed below.
Guided FTP Test Requirements
  • Activity must include heart rate data from a chest strap.
Automatic FTP Estimate Requirements
  • FTP Auto Calculation or Auto Detection must be enabled. For steps to locate this setting on your device refer to your owner's manual.
  • Activity includes heart rate data from a chest strap and you have ridden 70% Max HR with gradual increasing intensity for at least 5 minutes.
  • 95% of the average power for a 20-minute interval within the ride is greater than the current FTP setting.
Through either method the FTP estimate will only generate if the average power for that interval of time is greater than the previous 20-minute power record.
Back to Topics
Where Can I See My FTP Estimate in Garmin Connect?
Reports for previous FTP estimates are available in your Garmin Connect™ account. These reports are updated when a new FTP estimate has been generated from a recorded activity and when you have made manual changes to your FTP setting. Manual changes to FTP may not appear in reports until you have recorded a cycling activity and synced your device.
Garmin Connect App
  1. Open the Garmin Connect app.
  2. Select More (bottom right).
  3. Select Performance Stats.
  4. Select Functional Threshold Power.
Garmin Connect Web
  1. From a web browser, sign into your Garmin Connect account.
  2. Select Reports from the navigation bar on the left.
  3. Select Functional Threshold Power.
Back to Topics
Can I Input My Own FTP Reading?
You can add a manual reading on your device within your user profile under Power Zones. Entering a manual reading will turn off the auto-detect feature on the device. You can turn auto detection back on at any point and your device will continue providing estimates again.
Back to Topics
Related
