Troubleshooting an Issue Between a zūmo® 395 and a Bluetooth Headset
Troubleshoot in the Following Order if you Experience Issues Pairing a Bluetooth Headset/Helmet to Your Automotive Device or Encounter Issues While the two are Connected:
- Software Update
- Clear Pairing History
- Check Compatibility
- Check for Supported Audio Type
- Alternate Pairing Modes
Software Update
- Verify that the device is running the latest software version and that the Bluetooth firmware is up-to-date. To confirm or update your device's software, see the following FAQ: Updating Maps And Software With Garmin Express.
- It is recommended for your mobile phone and headset to have the latest software as well. Consult your phone and headset owner's manuals for guidance on how to update.
Clearing the pairing history on the automotive device and the phone will establish a new Bluetooth session between the devices. Step-by-step instructions for clearing the pairing history can be found below.
1. Touch Settings
2. Touch Bluetooth
3. Touch the device to delete
4. Scroll down and touch Unpair Device
5. Touch Yes
- If the headset is also paired to your phone, it is also recommended to clear the pairing history for this device on your phone as well.
Check Compatibility
Your device can receive the following audio prompts through a Bluetooth headset:
- Navigation Prompts - During navigation, when an instruction such as "Turn left in 500 feet" plays through the device, this prompt will be played in your headset.
- Phone Calls - As long as your phone and headset are both paired to the device, whenever you receive a phone call, the phone audio will be played through the headset.
- Bluetooth headsets/helmets (especially those designed for motorcycle usage) will often have multiple Bluetooth pairing modes. These are designed to give the Bluetooth accessory flexibility for different uses (phone, navigation, music, etc.). It may be necessary to try the other pairing modes offered by your headset to find one that works best with your Garmin device.
- The owner’s manual for your Bluetooth headset should include instructions on how to use these alternative pairing modes if it applies to your Bluetooth headset.
NOTE: A phone call is prioritized over any other audio. The device will mute spoken navigation prompts when a call is active. The visual on-screen navigation prompts continue. Navigation prompts resume when the phone call is disconnected.
