Downloading Golf Courses to Your Watch Using the Garmin Connect App
Some watches that support the Golf activity are not preloaded with golf course maps. For these watches, golf courses are downloaded, installed, and updated through the Garmin Connect™ app instead of the Garmin Express™ program. Once downloaded in the Garmin Connect app and added to your watch, your watch will display the 5 closest courses based on the GPS location of your watch.
Although courses are downloaded individually through the Garmin Connect app instead of through the Garmin Express program like devices that have preloaded mapping, the course information will be identical.
Downloading Golf Courses From the Garmin Connect App
  1. Open the Garmin Connect app.
  2. Select More (bottom right).
  3. Select Download Golf Courses.
  4. Select + (upper right corner).
  5. Search for a specific course by name.
  6. Select Download Icon next to the desired course.
    • The course list will be based on distance from the last known GPS location of your phone.
The course will now be saved in the Connect app, and is ready to sync to the watch when you are at the course. See the steps for adding golf courses to the watch for steps on transferring the course from the Garmin Connect app to your watch.
Deleting Golf Courses From the Garmin Connect App
The Garmin Connect app can store up to 100 courses. If you have reached the limit, select the option below for steps on deleting courses from the Garmin Connect app.
  • Android: Press and hold the course and then select REMOVE.
  • iOS: Swipe left on the course and then select Delete.
Adding Golf Courses to the Watch
  1. Select Start/Stop or Action key.
  2. Select Golf.
  3. Allow data to transfer.
The device will now show the 5 closest courses based on the GPS location of your watch. Select the course to be played, and the full course will be downloaded. The most recently played golf course will remain cached on the device once it is downloaded, and can be accessed without the need for a Bluetooth® connection.
Courses Are Not Syncing
If courses are not to your watch there may be an issue with the Bluetooth connection to the phone. Follow the steps in Garmin Connect App: Device Is Paired but Not Connecting to App to re-establish that Bluetooth connection to allow courses to sync over.
Related
