inReach Mini 2 Messaging Functions
Steps for sending and checking for messages on the inReach® Mini 2 handheld are provided below.
Sending a Text Message
- From the home page, press OK to open the main menu.
- Select Send Message.
- Choose recipients from your contacts list, or select Type Contact to enter each recipient's contact information.
- Select Next.
- Select an option:
- To start with a pre-written message, press
or
to scroll through the quick text messages.
NOTE: You can add and edit quick text messages on the Garmin Explore™ website. - To write a custom text message, select Type Message.
NOTE: To select from the autocomplete options, begin typing a word, hold OK, and useand
to scroll through the options.
- When you have finished your message, select
- Press OK to send the message.
Sending a Check-in Message
NOTE: Check-in messages have replaced preset messages as of September 27th, 2022. inReach® accounts set up prior to this date will still have preset messages available, but any new accounts created after this date will use check-in messages. With up-to-date software, these will be labeled on the device as Check-Ins in either case.
- Select Check-In.
- Press
or
to scroll through the Check-In messages.
- Press OK to select a Check-In message.
The content and recipients of the message appear. - Press OK to send the message.
Checking for Messages
or
to scroll through the widget glances.
- Select Check for Messages.
