Is the Electronic Control Unit (ECU) of my GHP 10 Autopilot ignition protected?
The Electronic Control Unit (ECU) of the GHP™ 10 marine autopilot has been tested for ignition protection.
The pump of the GHP 10 has not been tested for ignition protection as it does not connect directly to the power supply. The GHP 10's pump receives its power directly from the ECU.
