Comparing Garmin Pilot Web With the Garmin Pilot Mobile Application
Garmin Pilot Web is a flight planning companion to the Garmin Pilot™ app that allows you to flight plan from any computer. Whether you're on the computer at home, at work, a coffee shop, or an FBO, log in to Garmin Pilot Web to view airport information, weather, NOTAMS, and more, create and edit aircraft, and plan and file flights. Flights and aircraft sync seamlessly between Garmin Pilot Web and the Garmin Pilot App on your mobile device. See the table below to see the differences between Garmin Pilot Web and the Garmin Pilot app.
Feature | Garmin Pilot Web | Garmin Pilot Application |
Map | ✅ | ✅ |
| Side bar accessible on every page | ✅ | ✅ |
| Ability to zoom in / out | ✅ - by using the mouse wheel or pinching on the track pad | ✅ - by pinching or extending using your fingers on the screen |
| Ability to select data on the page | ✅ | ✅ |
| Overlays of weather and charts | ✅ | ✅ |
| Weather playback bar | ✅ | ✅ |
| Flight planning tools | ✅ | ✅ |
| Search bar | ✅ | ✅ |
| Airport information | ✅ | ✅ |
| Click and hover behavior | ✅ | ✅ |
Flights - For logged in users | ✅ | ✅ |
| Create flight buttons on map and flights page | ✅ | |
| Flight Sidebar | ✅ | |
| Mini inset map | ✅ | |
| ATC Route advisor arrivals and departures | ✅ | ✅ |
| Quickset Cards for fuel and payload planning | ✅ | |
Aircraft - For logged in users | ✅ | ✅ |
| Create aircraft manually | ✅ | ✅ |
| Create aircraft from template | ✅ | ✅ |
| Performance tables | ✅ | ✅ |
| Weight and balance | ✅ | ✅ |
| Synchronizing data across devices | ✅ | ✅ |
Visit pilotweb.garmin.com to try out Garmin Pilot Web today!
