Select the Menu.
Select Sensors.
Select the sensor you would like to remove.
Select Remove.
Select
Refer to your owner's manual for steps to add the sensor.
Occasionally you will need to remove a sensor from a Garmin® watch or Edge® cycling computer if you have accidently added it or need to troubleshoot the sensor. The process may vary slightly for each model, but refer to your product for general steps on how to remove the sensor.
Access the Menu on your watch.
Select Settings or
Select Sensors, Sensors and Accessories, or Connectivity > Sensors & Accessories.
Select Remove.
Select
Select the Menu.
Select Sensors.
Select Remove.
Select
