You are viewing an article that is not available in your currently selected language. You can choose another one below.
Automotive Device Not Detected by Garmin BaseCamp™ on a Mac Computer
USB communication issues can prevent your Garmin device from being detected by Garmin BaseCamp™.
Verify your Device Displays the Connection Icon
Your device should display an icon when connected to a computer.
These icons vary, but some examples include:
Garmin devices plugged into a computer tower via USB cable
Connect the USB cable directly to your Garmin device and not the mount (USB ports on mounts are for charging only)
USB Ports on the back of a Garmin Automotive GPS unit
Note: The device doesn't have enough power to communicate with the computer if the display is blank or only shows a Blank battery icon transparent battery icon when connected to the computer. Charge the device while driving using the vehicle power cable to ensure it has enough power.
Ensure the Mac Recognizes the USB Connection
A device will display as a removable disk drive in Finder when it is properly connected to a Mac computer.
To check whether OS X recognizes the connection:
1. Connect the Garmin device to the computer
2. Click the Finder icon on the dock
red box around smiley face icon
3. Click Go in the menu bar at the top of your computer screen
MAC menu bar with Go selected
4. Click Computer
MAC Go menu with Computer selected
The Garmin device will display as a disk drive icon and will generally be labeled GARMIN
Mac Finder window with available disk drives displayed
Device Does Not Display the Connection Screen or Display as a Drive in Finder
Try a different USB cable
Mini USB cable ends  Micro USB cable ends
    Mini USB Cable             Micro USB Cable
Ensure that the USB port is working properly
  • Try a different USB port on your computer and/or test the USB port with a different USB device
  • Avoid connecting through a USB hub, USB extension cable, keyboard, or monitor
  • On desktop computers, use the USB ports on the back of your computer
Garmin device connected to a laptop  USB cable plugged into back of desktop computer
Laptop                         Desktop
Macs with only USB-C Ports:
Some newer Mac computers may only have USB-C or Thunderbolt ports. It is best to connect your device directly to the computer when possible. If your device has a USB-C port, you can use a USB Type C to Type C data transfer cable. Apple has a helpful support article that explains different USB types, how to identify them, and what adapters can be used: Identify the ports on your Mac and Adapters for the Thunderbolt 4, Thunderbolt 3, or USB-C port on your Mac.
Macs with M1 and Newer Chips and USB-C Ports:
Automotive devices with miniUSB or microUSB ports must use a USB-C to USB adapter along with the appropriate miniUSB to USB-A or microUSB to USB-A cable provided with the device.
Automotive devices listed below may need to use a USB 2.0 third-party hub in order for the Garmin device to properly detect the USB connection.
  • BMW Motorrad Navigator V and VI
  • Camper 760 caravan and motorhome sat nav
  • Camper 780 caravan and motorhome sat nav
  • Camper 785 & Traffic caravan and motorhome sat nav with camera
  • Camper 890 caravan and motorhome sat nav
  • Camper 895 caravan and motorhome sat nav
  • Camper 1090 caravan and motorhome sat nav
  • Camper 1095 caravan and motorhome sat nav
  • Can-Am Spyder zūmo® 590LM
  • dēzl™ 560 GPS navigator
  • dēzl™ 760 GPS navigator
  • dēzl™ 770 GPS navigator
  • dēzl™ 780 GPS navigator
  • dēzl™ LGV500 | dēzl™ OTR500 GPS navigators
  • dēzl™ LGV610 | dēzl™ OTR610 GPS navigators
  • dēzl™ LGV700 | dēzl™ OTR700 GPS navigators
  • dēzl™ LGV710 | dēzl™ OTR710 GPS navigators
  • dēzl™ LGV800 | dēzl™ OTR800 GPS navigators
  • dēzl™ LGV810 | dēzl™ OTR810 GPS navigators
  • dēzl™ LGV1000 | dēzl™ OTR1000 GPS navigators
  • dēzl™ LGV1010 | dēzl™ OTR1010 GPS navigators
  • dēzlCam™ LMTHD GPS navigator with camera
  • dēzlCam™ 785 LMT-S GPS navigator with camera
  • dēzlCam™ LGV710 | dēzlCam™ OTR710 GPS navigators with camera
  • Garmin Catalyst™ Driving Performance Optimizer
  • Garmin Dash Cam™ 45
  • Garmin Dash Cam™ 46
  • Garmin Dash Cam™ 47
  • Garmin Dash Cam™ 54
  • Garmin Dash Cam™ 55
  • Garmin Dash Cam™ 56
  • Garmin Dash Cam™ 57
  • Garmin Dash Cam™ 65W
  • Garmin Dash Cam™ 66W
  • Garmin Dash Cam™ 67W
  • Garmin Dash Cam™ Mini
  • Garmin Dash Cam™ Mini 2
  • Garmin Dash Cam™ Tandem
  • Garmin DriveLuxe™ 50 GPS navigator
  • Garmin DriveLuxe™ 51 GPS navigator
  • Garmin Fleet™ 600 series
  • Garmin Fleet™ 700 series
  • Garmin Speak™ with Amazon Alexa
  • Garmin Speak™ Plus with Amazon Alexa with Built-in Dash Cam
  • Harley Davidson Roadtech zūmo® 590LM
  • nūviCam™ LMTHD GPS navigator with camera
  • Overlander® GPS navigator
  • RV 760 RV navigator
  • RV 780 RV navigator
  • RV 785 & Traffic RV navigator with camera
  • RV 890 RV navigator
  • RV 895 RV navigator
  • RV 1090 RV navigator
  • RV 1095 RV navigator
  • zūmo® 590 GPS navigator
  • zūmo® 595 GPS navigator
Macs with Other Types of USB Ports:
Connecting through a hub, USB extension cable, adapter, keyboard, or monitor is not recommended or supported.  Use the product compatible USB cable to connect directly to the computer.
Restart the computer and try again.
  1. Click the Apple icon in the menu bar
  2. Click Restart...
  3. Click Restart to confirm
Device is Recognized by the Mac but Not by the Garmin BaseCamp™
See Garmin BaseCamp™ Not Detecting Devices on Mac Catalina 10.15 or Big Sur 11.0 if you are on Mac Catalina or Big Sur.
Other programs may be actively communicating with your device while it is plugged into a computer. Try closing out other Garmin applications that may be reading your device.
  • Example: If Garmin BaseCamp™ is not seeing your device, but Garmin Express is, close Garmin Express.
See below if other programs are not interfering:
Ensure BaseCamp™ is up to date
  1. Click Garmin BaseCamp™ in the menu bar
  2. Click About Garmin BaseCamp™
  3. Click Check for Updates to BaseCamp™
    Note:
    Check for Updates will not be an option if BaseCamp™ up to date.
  4. Click Install Now and follow the prompts if an update available
Ensure that the Garmin is up to date
  1. Open Garmin Express
  2. Add or Select your Garmin
  3. Click Install Now if any updates are available
  4. Follow the prompts in Garmin Express to complete the update
If these steps did not resolve the issue
Visit the Garmin BaseCamp™ section of Support Center and you will find the available Product Support contact options in the Contact an Expert section.
