Replacing Approach Charging Cables
If the original Approach® charging cable is no longer charging the device, or otherwise damaged, a new charging cable will need to be purchased. If the Approach device is experiencing a charging problem, there may be troubleshooting steps to help fix the issue. For troubleshooting a charging issue, see My Approach Watch Will Not Power On or Charge.
Select the drop down below and locate the product link to purchase a charging cable or charging clip for your model.
Approach® R50
NOTE: These can be purchased separately, but both an AC adapter and compatible power cable are needed to power and charge your device
