Using the Daily Suggested Workout Feature on a Garmin Watch
Daily Suggested Workouts are workout recommendations made by your watch to provide a level of challenge to help you maintain or improve your current fitness level.
Using Daily Suggested Workouts:
What Data Is Used to Create Suggested Workouts?
The following items all factor into your workout suggestions:
  • Training Status
  • Training Load & Load Focus
  • VO2 Max Value
  • Recovery Time
  • Sleep Data
  • Profile of Recently Performed Workouts
  • Max Heart Rate, Lactate Threshold, or Functional Threshold Power
    • Daily Suggested Workouts will use the auto-detected Lactate Threshold and FTP values.
NOTE: Non-running/cycling activities that are performed on your Garmin watch do not directly affect the Daily Suggested Workouts. However, these non-running/cycling activities will affect your stress and therefore your recovery time, which does have a direct impact on your Daily Suggested Workouts.
What Watches Are Compatible With the Daily Suggested Workout Feature?
See the list below for watches compatible with the Daily Suggested Workout feature:
Compatible Watch List
  • D2™ Mach 1 |D2™ Mach 1 Pro
  • Descent™ G1 | Descent™ G1 Solar | Decent™ G1 Solar - Ocean Edition
  • Descent™ G2
  • Descent™ Mk2 | Descent™ Mk2i | Descent™ Mk2S
  • Enduro™
  • Enduro™ 2
  • Enduro™ 3
  • epix™ (Gen 2) - Standard Edition | epix™ (Gen 2) - Sapphire Edition | epix™ (Gen 2) - Porsche Edition
  • epix™ Pro (Gen 2) - Standard Edition | epix™ Pro (Gen 2) - Sapphire Edition
  • fēnix® 6S - Standard Edition | fēnix® 6S - Solar Edition | fēnix® 6S - Pro and Sapphire Editions | fēnix® 6S - Pro Solar Edition
  • fēnix® 6 - Standard Edition | fēnix® 6 - Solar Edition | fēnix® 6 - Pro and Sapphire Editions | fēnix® 6 - Pro Solar Edition
  • fēnix® 6X - Pro and Sapphire Editions | fēnix® 6X - Pro Solar Edition
  • fēnix® 7S - Standard Edition | fēnix® 7S - Solar Edition | fēnix® 7S - Sapphire Solar Edition
  • fēnix® 7 - Standard Edition | fēnix® 7 - Solar Edition | fēnix® 7 - Sapphire Solar Edition
  • fēnix® 7X - Solar Edition | fēnix® 7X - Sapphire Solar Edition
  • fēnix® 7S Pro - Solar Edition | fēnix® 7S Pro - Sapphire Solar Edition
  • fēnix® 7 Pro - Solar Edition | fēnix® 7 Pro - Sapphire Solar Edition
  • fēnix® 7X Pro - Solar Edition | fēnix® 7X Pro - Sapphire Solar Edition
  • fēnix® 8 - AMOLED Edition | fēnix® 8 - Solar Edition
  • fēnix® E
  • Forerunner 55 (Run only): For details specific to this watch model see:  Using Daily Suggested Workouts on Forerunner 55
  • Forerunner® 165 | Forerunner® 165 Music (Run only)
  • Forerunner® 245 Forerunner® 245 Music (Run only): For details specific to this watch model see: Using Daily Suggested Workout on Forerunner 245 or 245 Music
  • Forerunner® 255 | Forerunner® 255 Music | Forerunner® 255S | Forerunner® 255S Music
  • Forerunner® 265 | Forerunner® 265S
  • Forerunner® 745
  • Forerunner® 945 | Forerunner® 945 LTE
  • Forerunner® 955 | Forerunner® 955 Solar
  • Forerunner® 965
  • Instinct® 2 Solar | Instinct® 2 Solar - Tactical Edition | Instinct® 2 Solar - Surf Edition
  • Instinct® 2S - Standard Edition | Instinct® 2S - Camo Edition | Instinct® 2S - Surf Edition
  • Instinct® 2S Solar | Instinct® 2S Solar - Surf Edition
  • Instinct® 2X Solar | Instinct® 2X Solar - Tactical Edition
  • Instinct® 3 - AMOLED | Instinct® 3 - Solar
  • Instinct® E
  • Instinct® Crossover - Standard Edition | Instinct® Crossover Solar | Instinct® Crossover Solar - Tactical Edition
  • MARQ® Adventurer | MARQ® Athlete | MARQ® Aviator | MARQ® Captain | MARQ® Commander | MARQ® Driver | MARQ® Expedition | MARQ® Golfer
  • MARQ® Adventurer (Gen 2) | MARQ® Athlete (Gen 2) | MARQ® Aviator (Gen 2) | MARQ® Captain (Gen 2) | MARQ® Golfer (Gen 2)
  • MARQ® Adventurer (Gen 2) - Damascus Steel Edition | MARQ® Athlete (Gen 2) - Carbon Edition | MARQ® Athlete (Gen 2) - Performance Edition | MARQ® Commander (Gen 2) - Carbon Edition | MARQ® Golfer (Gen 2) - Carbon Edition
  • quatix® 6 | quatix® 6X Solar | quatix® 6 Titanium
  • quatix® 7 Pro | quatix® 7 - Standard Edition | quatix® 7 - Sapphire Edition | quatix® 7X - Solar Edition
  • tactix® 7 - AMOLED | tactix® 7 - Standard Edition | tactix® 7 - Pro Edition | tactix® 7 - Pro Ballistics Edition
  • tactix® 8 - AMOLED | tactix® 8 - Solar
  • tactix® Delta - Sapphire Edition | tactix® Delta - Solar Edition | tactix® Delta - Solar Edition with Ballistics
To activate the Daily Suggested Workouts feature, you must establish a VO2 max estimate. To do so, see: What Is VO2 Max Estimate and How Does It Work? Once you have a VO2 max estimate, you will see a Daily Suggested Workout notification the first time you access the "Run" or "Bike" activity profile. Here you can select to do the workout, dismiss the prompt, preview the workout steps, or disable the prompt from appearing on future days:
Suggest Workout Prompt on Watch
After completing the workout, you will no longer see the workout suggestion. If you dismiss the prompt you will still be able to access the suggested workout through the activity options or calendar widget on the watch:
Activity Options
  1. From the watch face, select Triangle Symbol on Top Right Watch Button or Start (top right button).
  2. Select the Run or Bike activity profile.
    • Some watches you will need to first select Activities.
  3. Press and hold Menu (middle left button) or scroll DOWN (bottom left button).
  4. Select Training.
  5. Select Workouts or Workout Library.
  6. Select Today's Suggestion.
Calendar Widget
  1. Press UP (middle left button) or DOWN (bottom left button) to scroll through the widget loop.
  2. Select the Calendar Widget.
  3. Select Suggested Workout.
I Do Not Receive a Daily Suggested Workout on My Watch
If you are following a dedicated training plan with scheduled workouts aimed at a specific event, one downloaded from Garmin Connect (either a Garmin plan or one you have created), or one downloaded from a third party, these training plan workouts will take priority over the Daily Suggested Workouts. You will still be able to locate the suggested workout in the workouts menu, but your training plan workouts will take priority in the prompts given on your watch.
There are a few other reasons why you may not receive a Daily Suggested Workout on your watch:
Refer to this FAQ if you are not receiving a VO2 Max estimate.
If you have disabled the Daily Suggested Workout prompt you can enable the prompt by doing the following:
  1. Press Triangle Symbol on Top Right Watch Button or Start (top right button).
  4. Select Training.
  7. Press Triangle Symbol on Top Right Watch Button or Start (top right button).
    • Some watches you will need to first select Settings.
  8. Select Enable Prompt or Workout Prompt.
You have enabled the prompt and will automatically receive Daily Suggested Workout prompts for future workouts.
Related
