Adding Shortcuts to a fēnix E Watch
Garmin fēnix® E watches offer shortcut options which allows for the customization of buttons to quickly access specific settings or options on the watch. These shortcuts assign secondary functions to the watch buttons instead of needing to make the selections from the watch menus. To access the function programed as a shortcut, hold the specified button or button combination for two seconds. See the video below for more information:
Customizing the Shortcut buttons for a fēnix E Watch
Hold UP/MENU (middle left button) to open the menu.
Select Watch Settings.
Select System.
Select Shortcuts.
Select the button you wish to assign a Shortcut.
Select the Shortcut option.
For a list of available Shortcuts and options, select an option below.
Available Buttons and Button Combinations
Your watch comes with some shortcuts preprogramed but you can customize what happens when you hold the following buttons or button combinations.
