Press and hold UP/MENU (middle-left button).
Select or scroll to Settings.
This step may not be required on some watches.
Select Activities & Apps.
Select the activity that is auto-scrolling.
Select (Activity Name) Settings.
Select Auto Climb.
Change Invert Colors to Off.
My Garmin Outdoor Watch Continues to Auto-Scroll and Background Changes Color
If your outdoor watch continues to auto-scroll and change color, even after disabling the Auto Scroll setting, it means that you are using an activity with Auto Climb enabled. To disable the Auto Climb setting, follow the steps below.
Disabling Auto Climb on an Outdoor Watch
Select (Activity name) Settings.
Select Auto Climb.
Change Status to Off.
You may wish to remove color inversion or change the elevation change required to trigger Auto Climb as well.
NOTE: Not all models compatible with Auto Climb will have the settings listed below.
