Missing Drive Widget on the Overlander®
Your device has a customizable home screen. The widgets can be moved to different places on the home screen or removed completely. If you have accidentally removed the Drive menu, it can be replaced.
To Replace the Drive Widget:
1. Hold your finger down on the home screen in the empty space
2. Touch Widgets
3. Scroll down to the Garmin Navigation section
4. Touch and hold Drive
5. Drag the widget to the desired place on the home screen
You will now have the option to select Drive from the main menu screen.
