How to Mute or Change Alert Tones on Garmin Dash Cams
Depending on your dash cam model, there are different ways to mute or change the alert tones on the device. Select your dash cam in the expandable sections below for directions.
Garmin Dash Cam™ X110 | Garmin Dash Cam™ X210 | Garmin Dash Cam™ X310 | Garmin Dash Cam™ Live | Garmin Dash Cam™ 47 | Garmin Dash Cam™ 57 | Garmin Dash Cam™ 67W | Garmin Dash Cam™ Tandem | Garmin Dash Cam™ 46 | Garmin Dash Cam™ 56 | Garmin Dash Cam™ 66W Driving Recorders
To Change or Mute the Alert Volume via the Garmin Drive™ App:
1. Connect the Garmin Dash Cam with the Garmin Drive app
NOTE: The dash cam must be fully connected in order to access the Alert Volume.
2. Touch the Gear icon in the Garmin Drive app
Drive App New - Settings Gear
3. Select the relevant dash cam from within the Vehicle
Drive App New - Settings, Device
4. Select Alert Volume
 Drive App New - Alert Volume DC Live
5. Select the desired volume level
Alert Options
To Change Alert Volume on Dash Cams with a Built-In Display:
The overall volume of the dash cam can be adjusted on dash cams with a built-in display. See the steps in the dash cam's owner's manual for guidance: Let's Find the Manual for Your Device
Garmin Dash Cam™ Mini 2 | Garmin Dash Cam™ Mini 3 Driving Recorders
NOTE: A Garmin Dash Cam Mini 2 driving recorder must have software version 2.70 or higher to control the alert tone using the Garmin Drive™ app. See  Updating a Garmin Dash Cam with the Garmin Drive App to update the software.
To Toggle the Alert Tone On or Off in the Garmin Drive™ App:
NOTE: The dash cam must be powered and connected in order to access the Alert Volume.
4. Look for Alert Volume
5. Select the desired volume level:  On or Mute
Alert Volume On Off
Garmin Dash Cam™ 45 | Garmin Dash Cam™ 54 | Garmin Dash Cam™ 55 | Garmin Dash Cam™ 65W Driving Recorders
Alert Tones can be turned on or off by following the steps below:
  1. Press the up or down buttons Carrot Selection ButtonDown Carrot Selection Button on the side of the dash cam until Settings is displayed
  2. Press the Confirm selection button button to select Settings
  3. Select Driver Assistance
  4. Disable Alert tones as desired
Alternatively, the overall volume of the device can be adjusted as well:
  3. Select System
  4. Select Volume
  5. Adjust the volume level as desired with the up and down buttons Carrot Selection ButtonDown Carrot Selection Button
Garmin Dash Cam™ 30 | Garmin Dash Cam™ 35 Driving Recorders
  1. Press the button until Settings displays on the screen
  2. Press the button to select Settings
  3. Press the up or down buttons until Alert Tone is highlighted
  4. Press the button
  5. Press the up or down buttons until the desired option is highlighted
  6. Press the button
Alert Tones will now be enabled or disabled.
NOTE: The Garmin Dash Cam™ Mini, Garmin Dash Cam™ 10, and Garmin Dash Cam™ 20 driving recorders have no options for volume adjustment.
Related
