Alpha 200 or Alpha 200i Calibrating the Compass
Calibrating the electronic compass on your Alpha® 200 and Alpha® 200i should be done from time to time. You should calibrate the compass after travelling long distances, experiencing temperature changes, or after removing the battery.
NOTE: To improve heading accuracy, do not stand near objects that influence magnetic fields, such as vehicles, buildings, and overhead power lines.
Calibrating the Electronics Compass
  1. From the Main Menu, select the Compass
  2. Select the Menu icon (three lines)
  3. Select Calibrate Compass
  4. Select Start
  5. Follow the onscreen instructions
