Acura NSX Vehicle Lost Power During a Map Update
The engine will need to be running in your Acura NSX vehicle when installing the map update. The vehicle should be parked outside or in a well-ventilated area during this process.
Resume following the map update instructions from the last step you successfully completed if the vehicle loses power during the map update installation.
