Resolving Inaccurate or Incorrect Distances on an Approach Series Watch
As with any GPS product, distance to a certain geographical location is important. This is especially true when using a Garmin® golf watch to determine yardage. If you are experiencing inaccuracies, it is important to understand what can affect yardage readings.
Inaccuracies should be compared against course markers. Course markers generally measure to the center of the green, not the hole. This is important to remember because it can mean the difference of 20 to 30 yards on some shots. The golf watch will measure to the center of green by default.
Common Cause of Inaccuracy
The most common cause of inaccurate distance readings is that unit settings are set incorrectly to either metric or yards. If your local course measures distance in metric, but your watch is set to yards, the distance will consistently be off. The golf distance units can be checked directly on your Approach® watch.
Approach S1 | Approach S2
  1. Hold OK/Menu.
  2. Select Setup.
  3. Select Units.
  4. Select Yards or Meters.
Approach S3 | Approach S4 | Approach S5 | Approach S6
  1. From the time, touch Menu Button.
  2. Select Setup.
  3. Select Units.
Approach S10
  1. Press OK.
  2. Select Settings.
  3. Select Units.
Approach S12
  1. Press OK.
  2. Select Golf Settings.
  3. Select Golf Distance.
Approach S20
  1. Press OK.
  2. Select Settings.
  3. Select Units.
Approach S40 | Approach S42
  1. Press and hold the Button.
  2. Select Settings.
  3. Select Units.
  4. Select Golf Distance.
  5. Select Yards or Meters.
Approach S44 | Approach S50
  1. Press and hold the Top Button.
  2. Select Settings.
  3. Select Golf Settings.
Approach S60
  1. Press Menu Button.
  2. Select Settings.
  3. Select System.
  4. Select Units.
  5. Select Distance.
  6. Select Yards or Meters.
Approach S62
  2. Select Settings.
  3. Select System.
  4. Select Units.
  5. Select Golf Distance.
Approach S70 - 42mm | Approach S70 - 47mm
  2. Select Settings.
Approach X10
  1. Press the Device Key.
  2. Select Gear Icon.
  3. Select Units.
Approach X40
  3. Select System.
  4. Select Units.
  5. Yards or Meters.
Other Possible Causes of Inaccuracy
  • Watch does not have a clear view of the sky for a strong satellite lock.
  • CourseView version, software and chipset need to be updated. For assistance updating your software and maps with Garmin Express™. For instructions on updating your watch, see - Update Golf Courses and Device Software on an Approach.
  • Pin placement was manually moved away from the center of green.
  • PlaysLike Distance (adjusts distances accounting for elevation) is enabled. For tips on how to use or disable PlaysLike Distance on your watch, see the owner's manual.
Golf Course Remodels
Some inaccuracies can be the result of golf course remodeling and other situations where our Garmin course database will be in need of an update. To help notify us about an upcoming or needed update please fill out a Golf Course Report Form or if yardage inaccuracies exist with a specific hole or course under the following conditions:
  • Present on one or more holes but not the entire course.
  • Occurs with one course but not others.
As with any consumer grade product GPS inaccuracies will exist. Therefore, a yardage discrepancy of 5 yards or less is more than acceptable and would not be considered an issue.
