Automotive Device Prompting to Simulate Route
You can use your device indoors, or in a location where you cannot get an adequate GPS signal, by enabling Simulator Mode. When this happens, the device uses your last known location and simulates navigating a route. The device is not locked onto satellite signals but acts as though it is navigating a route.
To begin navigating a route in real-time, you will need to ensure the device has a clear view of the sky to acquire satellite signals, then enable Location Services on your device.
To Enable the Location on the Device:
- Open the device's Settings menu
- Touch Personal
- Some devices skip this step
- Touch Location
- Touch the switch next to Location to turn it on
The location will now be enabled and the device will now navigate you through each step of the route.
