Showing Items on the Map of an Outdoor Handheld at Different Zoom Levels
If you are not able to see icons or labels for waypoints, points of interest (POI), or other items on the map of your outdoor handheld, you may need to adjust the zoom level at which map items appear. Map items do not appear when the map zoom level is higher than the selected level. To change this setting, refer to your specific handheld model below.
eTrex® 20, 20x, 22x, 30, 30x, or 32x Outdoor Handhelds
  1. Select Setup from the main menu.
  2. Select Map.
  3. Select Advanced Map Setup.
  4. Select Adjust Zoom Ranges.
  5. Select Zoom Levels.
  6. Select a category to adjust the zoom level at which it will appear on the map.
eTrex® Touch 25, 35, and 35t Outdoor Handhelds
  1. Press Power Button to open the app drawer.
  2. Select Setup.
  3. Select Map.
  4. Select Advanced Setup.
GPSMAP® 62, 64, and 65 Series Outdoor Handhelds
These steps apply to the following GPSMAP handheld models:
  • GPSMAP 62 | GPSMAP 62s | GPSMAP 62sc | GPSMAP 62st | GPSMAP 62stc
  • GPSMAP 64 | GPSMAP 64s | GPSMAP 64sc | GPSMAP 64st
  • GPSMAP 64sx | GPSMAP 64csx | GPSMAP 64x
  • GPSMAP 65 |  GPSMAP 65s
  1. Press MENU twice to access the main menu.
  2. Select Setup.
  3. Select Map.
  4. Select Advanced Map Setup.
  5. Select Adjust Zoom Ranges.
  6. Select Zoom Levels.
  7. Select a category to adjust the zoom level at which it will appear on the map.
GPSMAP® 66, 67, or 86 Series Outdoor Handhelds
  • GPSMAP 66i | GPSMAP 66s | GPSMAP 66sr | GPSMAP 66st
  • GPSMAP 67 | GPSMAP 67i
  • GPSMAP 86i | GPSMAP 86s | GPSMAP 86sc | GPSMAP 86sci
  2. Select Setup.
  3. Select Map.
Montana® 600, 610, 650, and 680 Series Outdoor Handhelds
These steps apply to the Montana 600, 600t Camo, 610, 610t Camo, 650, 650t, 680, and 680t.
  1. Touch Arrow to open the app drawer.
  2. Select Setup.
  3. Select Map.
  5. Select Zoom Ranges.
Montana® 700 Series Outdoor Handhelds
These steps apply to the Montana 700, 700i, 710, 710i, 750i, and 760i.
  1. Touch Home to reach the main menu.
  2. Select Setup.
  3. Select Map.
Oregon® 600 Series Outdoor Handhelds
These steps apply to the Oregon 600, 600t, 650, and 650t.
  1. From the home screen, swipe bottom to top in portrait mode or left to right in landscape mode to open the app drawer.
  2. Select Setup.
  3. Select Map.
Oregon® 700, 750, and 750t Outdoor Handhelds
NOTE: The user interface on these devices is set to Activity Mode by default, but they can be changed to Classic Mode by going to the app drawer and selecting Setup > System > Mode.
  1. Open the app drawer.
    • Activity Mode: Press Power Button.
    • Classic Mode: From the home screen, swipe bottom to top in portrait mode or left to right in landscape mode.
  2. Select Setup.
  3. Select Map.
  5. Select Zoom Controls.
Rino® 750, 750t, and 755t Outdoor Handhelds
NOTE: The user interface on the Rino 750, 750t, and 755t is set to Classic Mode by default, but it can be changed to Activity Mode by going to the app drawer and selecting Setup > System > Mode.
  2. Select Setup.
  3. Select Map.
