MediaMaster® MMR-40 Software Update/Installation Process
MediaMaster® MMR-40 OS Update
This update includes:
  • Added MM55 / MM55-HR Support
  • General UI Improvements
  • General Bug Fixes
Follow these steps to view which software version is currently loaded in your MediaMaster® MMR-40:
  1. With the MMR-40 turned on, press and hold SETTINGS to access the System Settings: Main Menu.
  2. Rotate the VOL/SEL knob clockwise to Diagnostic; then press and release the VOL/SEL knob to select.
  3. The software version currently in use will be displayed after SW ver:
Follow the steps below to download and install (or reinstall) the latest operating software for the MediaMaster® MMR-40:
  1. Download the latest update (ver: 20240710171747) below.
  2. Extract the files and review the included PDF license agreement (MM_OS_EULA.pdf).
  3. Save the .bin file (highlighted below) to a USB thumb drive. (Thumb drive should be empty and formatted to FAT32.)
    MM40 JL Audio Update Folder
    Note: This file should be saved to the root directory (top level) of the thumb drive (not placed in a folder).
  4. Disconnect the MMR-40 from the NMEA 2000® network.
  5. Insert the USB thumb drive into the USB port of the MMR-40.
  6. Reconnect the MMR-40 to a powered NMEA 2000® network to begin its startup.
  7. In the following moments (about one minute total), a series of messages ("USB Initialization", "Search for Firmware", "Firmware was found", "Erasing" "Flashing", "Starting", etc) will appear in succession, just above the yellow line on the display screen as the update proceeds automatically. **
Once the update is completed, the MMR-40 will reboot and its display will go to sleep. Simply press the SOURCE button to begin listening.
Note:We recommend following the steps at the top to verify that the latest software version was successfully installed. Do not forget to unplug/remove the USB thumb drive from the MMR-40.
** If the update did not automatically begin upon applying +12VDC, navigate to the Diagnostic menu again and rotate the VOL/SEL knob clockwise until "Enter SW Update Mode" is selected. Press the VOL/SEL to select it.
Entering Software Update Mode JL Audio
A prompt to proceed with the update will appear, be sure the USB thumb drive with the proper file is connected at this time. Rotate the VOL/SEL knob clockwise to highlight "Yes", press the VOL/SEL knob once to continue.
JL Audio Software Update Mode
Related
