Updating Software on Your Vector, Vector S, Vector 2/2S Power Meter System
To update the software on your Vector, Vector S, Vector 2/2S Power Meter system, download and install  Vector Updater. This software will allow you to pair your Vector power meter to your computer using the included USB ANT Stick to ensure the software is up to date.
Alternatively, the Vector power meter can receive a software update when paired with a compatible Garmin device. To see if your device is compatible with power meters please check your owner's manual.
If you sync your device with Garmin Express, any available update for Vector will be downloaded.  When you connect Vector to your device, you should be prompted to install the update to your pedals.
