Differences Between Preset, Check-in, and Quick Text Messages
The chart below best shows the differences between preset, check-in, and quick text messages when using an inReach® satellite communication device.
NOTE: Check-in messages have replaced preset messages as of September 27th, 2022. inReach® accounts set up prior to this date will still have preset messages available, but any new accounts created after this date will use check-in messages.
Preset Messages Prior to September 27th, 2022 | Check-in Messages Current | Quick Text Messages | |
How many can I have? | 3 | 3 | 20 |
Who is the message sent to? | Determined ahead of time by user on the account at explore.garmin.com | Determined ahead of time by user on the account at explore.garmin.com, or in the Garmin Messenger app with a compatible inReach device. | Determined when sending the message |
What does the message say? | Determined ahead of time by user on the account at explore.garmin.com. A Preset is not to be used for an Emergency. |
Do sent messages count against my monthly satellite message allotment? | No, except for Enterprise plans and the Enabled plan | No, except for Enterprise plans and the Enabled plan | Yes |
Do received messages count against my monthly satellite message allotment? | No. Except for Enterprise plans and the Enabled plan, preset messages received from another inReach user do not count against your monthly satellite message allotment. | No. Except for Enterprise plans and the Enabled plan, check-in messages received from another inReach user do not count against your monthly satellite message allotment. | Yes |
IMPORTANT: Any received messages, including replies to preset, check-in, and quick text messages, will count against your monthly satellite message allotment. However, incoming check-in or preset messages received from another inReach user will not count against your monthly message allotment, except for Enterprise plans and the Enabled plan.
For instructions on sending a preset or check-in message from an inReach handheld or Tread device, refer to the appropriate link for the device below:
