You are viewing an article that is not available in your currently selected language. You can choose another one below.
How to Format the Memory Card for the Varia RCT715 and Varia Vue
Your Varia™ RCT715 or Varia™ Vue uses a microSD memory card to record and store video footage and may require occasional formatting to delete history, prevent errors, and prolong the usable life of the card.
IMPORTANT: Only reformat the microSD card using the Varia™ app. Using a computer to reformat the card may result in an incompatible format.
Reformat the SD Card in The Varia App
  1. Open the Varia app.
  2. Power on your Varia so it pairs with the app.
  3. Select Three blue dots stacked vertically (top right).
    Varia app showing RCT715 connected with three blue dots menu in the top right corner
  4. Select Devices.
  5. Select your Varia device.
  6. Select Gallery & Storage > Erase & Reformat Card.
  7. Select Erase & Format > Erase & Format. This will erase all data on the SD card! This action cannot be undone.
    Varia App showing option to Format Memory Card  Pop up asking to confirm Erase and Format memory card
Reformat the Memory Card from an Edge Cycling Computer
Some models of Edge® cycling computer can reformat the card on a Varia Vue in an incompatible format is detected by the camera. You will receive a prompt to format the memory card of your Varia Vue if this is detected by the camera.
Related
