Software Updates for Alpha T20 and Alpha TT25 Collars
The Alpha® T 20 and Alpha® TT 25 series collars can have their software updated via Wi-Fi or through Garmin Express™ software (see related content below for Garmin Express instructions).
Updating Software On Your Collars
There are two methods available to setup the Wi-Fi on your collar.
Setup Collars Wi-Fi Through Garmin Express™ Software
  1. Connect your collar to your Windows or Mac computer
  2. Open Garmin Express program
  3. Choose Add Device if you have not already done so
  4. You are prompted to enter an email address if you want to register your collar
  5. Select Next
  6. Choose a Nickname for your collar (helpful to use an identifying name if you have multiple collars) and select Next
  7. If you see a network already listed your collar is already setup, if not select Add a New Network¹
  8. Choose a network from those available and complete the process
Setup Collar Wi-Fi Through a Handheld
Alpha 200/300 Series Handhelds
  1. From the Dog List select the collar for which you want to setup the Wi-Fi
  2. In the lower right, select the menu icon (3 horizontal lines)
  3. Select Collar Wi-Fi Setup
  4. You will see a prompt that the collar is scanning for nearby networks
  5. Select the network to which you want your collar to connect and enter the password
  6. Select the green check mark when you're finished entering the password
Alpha XL
  1. Select Dog List Alpha XL dog
  2. Select the collar for which you want to setup the Wi-Fi
  3. Select the Down Arrow Alpha xl more next to the dogs name
  4. Select Collar Settings
  5. Select Collar Wi-Fi Setup
  6. You will see a prompt that the collar is scanning for nearby networks
  7. Select the network you want your collar to connect to and enter the password
  8. Select the green check mark when done
Software updated through Wi-Fi will be done when the collar is on the charger and has a good Wi-Fi signal. The update process over Wi-Fi may take 30-45 minutes. When the software update process takes place the collar LED will flash white indicating that it is installing the software update.
¹See product manual for device specifications. The Alpha T20 and Alpha TT25 do not support 5 GHz Wi-Fi.
Note: Wi-Fi setup is not available on the Alpha 100, Alpha 10 or Pro 550 Plus.
Related
