Index S2 Scale: Power to Weight Ratio Widget
Index S2 scale users that have cycling functional threshold power (FTP) data in their Garmin Connect account can enable a widget on their scale in order to see the power to weight ratio of their FTP.
Requirements to use this feature include:
What Is Power to Weight Ratio?
Power to weight ratio is a way to compare absolute power numbers with other riders and is simply how much power per kilogram the cyclist is capable of generating. The higher the number the better. For this feature, we are looking at the Power to Weight Ratio of your FTP. However, it can also be applied in other areas, such as comparing absolute power values between riders during a segment or over an entire ride that they did together.
How Do You Calculate Power to Weight Ratio?
If you have an FTP value, your power (watts) is divided by your weight in Kilograms. See the image below for an example:
Power to Weight Ratio Measurement from Garmin Connect
Why Should I Be Interested in Power to Weight Ratio?
As a cyclist, you may be interested in knowing how much power you can generate per kilogram of body weight. Ideally you want as high a power as your weight can generate. However, losing too much weight might cause you to lose muscle or power. Gaining too much weight without adding power will also cause the ratio to go down. Power to Weight Ratio is also a good way to objectively compare your performance to others.
What Is a Good Power to Weight Ratio for My FTP?
Males (W/kg)Females (W/kg)
Superior5.05 and greater4.30 and greater
ExcellentFrom 3.93 to 5.04From 3.33 to 4.29
GoodFrom 2.79 to 3.92From 2.36 to 3.32
FairFrom 2.23 to 2.78From 1.90 to 2.35
UntrainedLess than 2.22Less than 1.89
How Does My Power to Weight Ratio Change?
This metric will change as your weight changes or as your FTP changes. Each time you stand on the scale or record a new FTP, the ratio will update.
Can I See My Progress in Garmin Connect?
Yes. This metric is tracked in Reports in Garmin Connect online and in the Garmin Connect app under “Functional Threshold Power”.
How Do I Turn the Widget On or Off?
    1. Open the Garmin Connect app.
    2. Access the menu by selecting More (bottom right).
    3. Select Garmin Devices.
    4. Select Index S2.
    5. Select Appearance > Widgets.
    6. Toggle the Power-to-Weight Ratio widget on or off.
screenshot showing widget options for the Index S2 scale.
