How Do I Setup My Garmin Alpha 100?
Before heading out with your system, we recommend that you set it up and make sure it's ready to use.
Charging
You will first want to make sure that both the Alpha® 100 and your collar(s) are properly charged1. The Alpha 100 requires the battery to be present to transmit.
A solid red LED indicates that the collar is charging
A solid green LED indicates that the collar is fully charged
1Products containing Lithium-Ion batteries are purposely shipped with less than a full charge
Pairing
After your handheld and collars are fully charged, you can turn them on and pair them. Tap Dog List, if you have no collars listed or not all collars listed, you will want to pair them to your handheld.
If you purchased an Alpha 100 bundle with TT™ 15 or TT™ 15 mini they should already be paired to the handheld
Additional collars will need to be paired
TIP: Enter the dogs in the order in which you'd like to most to see them
Select Pairing a New or Additional Collar below for steps on pairing a new collar to your handheld.
If your collar is not paired, turn it off to start.
Turn on the collar by pressing and holding the Power button until the collar beeps twice.
The LED on the collar should be flashing rapidly in green. It is now ready to be paired to the handheld.
On the handheld:
Tap Dog List
Tap + Add Dog
Bring the collar near the handheld and tap Yes
Keep the collar near the handheld until it the handheld gives you the screen to enter the dog’s name
After you’ve entered the dog’s name, tap the to indicate okay
If you plan to pair collars by using a Track or Train Code from another dog tracking or training handheld, select Pairing with a Track or Train Code below.
Turn on the collar by pressing and holding the Power button until the collar beeps twice. The
On the handheld:
Tap Dog List
Tap + Add Dog
Bring the collar near the handheld and tap No
Tap Yes when asked if you know the track or train code
Enter Track or Train code and tap
Acquiring Satellites
After you’ve added all the dogs you intend to add, it’s best to give the handheld and collars an unobstructed view of the sky to acquire as many satellites as possible, and to familiarize themselves with where the satellites are in the sky. On the collar when you have a good fix you'll see 3 rapid green flashes in a row from the LED.
TIP: If traveling more than a few miles away from where the handheld and collar obtained GPS connection, it is suggested that you repeat this effort again at the new location but before you use them in the field.
BirdsEye Satellite Imagery and Additional Mapping
Are you going to put BirdsEye Satellite Imagery on your Alpha 100 or have another map you want to install, like HuntView Plus, the articles below will help depending on your situation:
