Disabling/Enabling Charts on GPSMAP 2xxx and 3xxx Series Devices
The GPSMAP 2000 and 3000 series of devices are able to disable and enable maps to prevent any mapping display issues. If two maps of the same area are enabled simultaneously, the chartplotter may not display either map properly.
Enable/Disable chart on 2000 series devices
  1. Press Menu
  2. Toggle Down to Map
  3. Toggle Right To Source
    • Basemap enables or disables the built-in basemap
    • Data Card Maps enables or disables any mapping cards
    • The Card Maps soft key allows individual charts to be enabled or disabled
      • To ensure that all data card maps are enabled, press Show All after pressing Card Maps
Enable/Disable charts on 3000 series devices
  1. Press and Hold the ADJ/Menu button until the Main Menu appears
  3. Toggle Right to Source
    • Built-in Map enables or disables the pre-loaded mapping
    • External Maps enables or disables any mapping cards
    • The Advanced soft key allows individual charts to be enabled or disabled
      • To ensure that all data card maps are enabled, press Show All after pressing Advanced
Disabling a map will hide all detail from the chart. If expected detail is not showing on the chart, enabling all maps may correct the issue.
