Editing and Viewing Saved Tracks
You can customize and edit saved tracks directly on the device.
Viewing and Editing a Saved Track:
  1. Open Apps
    • On the Tread 2 Series:
      • Touch Saved
      • Touch the arrow and select Tracks
      • Select a track
      • Skip to #6 below
  2. Touch Adventure
  3. Touch Tracks
  4. Select the track you would like to View or Edit
  5. TouchInformation Icon Symbol to view the track
  6. Touch to see other track data such as speed, elevation, and sharp turns.
  7. Select the Edit Icon, the track will now open on the map.
    • Add allows you to add more points to the track.
    • Delete allows you to remove a track point.
    • Move allows you to move a track point.
    • Reverse changes the position of the Start and Finish flags.
    • Join allows you to select a point of the track and join it with another track from your Track Library.
    • discards any changes made.
    • undo icon allows you to undo the last change.
  8. Select Save when you finish your changes
