(2024) Service Bulletin 24042 Rev B: Approval of Part 23 GTX™ 3X5(R) Series Main Software Version 2.85 and ADS-B Software Version 3.51
PRODUCTS AFFECTED:
GTX 3X5(R) Series units installed using Part 23 ADS-B AML STC SA01714WI are affected.
CERTIFICATION AUTHORIZATION:
SA01714WI MDL Revision 23
COMPLIANCE:
Recommended: Compliance with Service Bulletin 24042 is recommended at the next scheduled maintenance interval.
DOCUMENTATION CONSIDERATIONS
As a result of the aircraft modification with this STC, The AFMS, Garmin GTX 33X and GTX 3X5 Transponders with ADS-B, 190-00734-15, Rev. 6 is required to be issued to the aircraft owner/operator before the aircraft is returned to service.
The current revision of the GTX 3X5 Series Pilot’s Guide (Garmin P/N 190-01499-00) Rev G is applicable.
PURPOSE:
This STC Service Bulletin provides notification of an update to STC SA01714WI, GTX 3X5(R) with ADS-B AML STC, MDL Revision 23.
MDL Revision 23 approves the following software changes:
GTX 3X5 Main Software Version 2.85:
  • Improved display handling of the alert message dialog subpage
  • Improvements to the software calibration procedure for units with internal AHRS (GTX 345 only)
  • Improved the robustness of non-volatile memory data to prevent unit failure due to loss of data
CAUTION
Not upgrading software may result in the unit being returned to the factory due to a loss of calibration data.
GTX 3X5 ADS-B Software Version 3.51:
  • Improved the AHRS calibration procedure and calibration validity checks
  • Corrected an issue where assert log information could not be downloaded using HSDB
  • Expanded support for flight data log retrieval using HSDB
  • Expanded support for transponder health diagnostic information to be transmitted using HSDB
  • Expanded support for sourcing of different sensor data for additional systems that have a pilot/copilot flight director transfer switch
  • Expanded flight data logging capability to include internal AHRS data
  • Improved the ADS-B SURF application status reporting
  • Addressed a timing issue that could result in TAS/TCAS-only targets being temporarily removed from the traffic display intermittently
  • Corrected an issue where daily NOTAM TFRs were only displayed on the first day that they were published. Daily NOTAM TFRs are now displayed until they are no longer active.
  • Updated aural alert processing to use a heading-based bearing for TAS/TCAS targets. This now matches functionality for ADS-B targets and improves directional callout accuracy primarily for rotorcraft.
WARRANTY INFORMATION:
This modification is warranty reimbursable with a deadline of December 31, 2025.
Related
