How do I Install a fleet 790 SIM Card?
The form factor for the Garmin fleet 790 SIM card is a Micro-SIM (3FF).  A Nano-SIM card (4FF) can also be used along with a Micro-SIM Adapter.
Before a SIM can be installed or replaced, the device must be powered off first.
To install or replace the SIM card:
1.  Remove the two Phillips head screws using a #1 Phillips head screwdriver
    • View figure #1 to locate the two screws
2.  Insert the SIM into the left-most slot
    • View figure #2 to locate the slot
3. Press in on the SIM card until it "clicks"
4. Replace the panel, tighten the screws, and power on the device
