D2™ Mach 1 | D2™ Mach 1 Pro
Descent™ Mk2i
Descent™ Mk3 | Descent™ Mk3i
Instinct® 2 Solar - Tactical Edition | Instinct® 2X Solar - Tactical Edition
Instinct® Crossover Solar - Tactical Edition
Instinct® Solar - Tactical Edition
Instinct® - Tactical Edition
MARQ® Commander
MARQ® Commander (Gen 2) - Carbon Edition
tactix® 7 - AMOLED Edition | tactix® 7 - Standard Edition | tactix® 7 - Pro Edition | tactix® 7 - Pro Ballistics Edition
tactix® 8 - AMOLED | tactix® 8 - Solar
tactix® Delta - Sapphire Edition | tactix® Delta - Solar Edition | tactix® Delta - Solar Edition with Ballistics
Stealth Mode on Garmin Tactical Watches
Stealth Mode can be enabled to turn off the storage and sharing of your GPS position, and all wireless communication on the watch. This can be useful in secure areas where wireless communication is prohibited. Activities can still be started to monitor time, pace, elevation, and distance, but GPS location information will not be saved on the watch.
Stealth Mode must be enabled prior to starting a GPS enabled activity and can only be activated from the controls menu. See Enabling/Disabling Stealth Mode below, or your owner's manual for steps.
NOTE: Saving a GPS location (waypoint) is also disabled when Stealth Mode is active.
Press and Hold Light.
Select
When enabled, Stealth Mode disables:
Location track logging
Bluetooth® communication
ANT+ communication
Wi-Fi® connectivity (if applicable)
