Expert Assist: Making Manual Adjustments for Level
Image shows applied level optimization trim for Left Tweeter
When Expert Assist is performing the Autoset Levels Procedure, the user is given an opportunity to make adjustments to the level output of each channel. If the data does not match up with the Target properly, the user can manually adjust the level of that channel to be positioned properly.It is important to note, by pressing “OK” the user is accepting that they are happy with the results. This means that if the results are poor, the user accepted it. It is always the user’s responsibility to make sure the results are sufficient.
