Mounting Multiple Transom Transducers
In some boating applications, it is beneficial to have both a traditional transom mounted transducer and a ClearVü/SideVü transom mounted transducer.
When mounting the ClearVü/SideVü transducer, insure that it is on a lower horizontal plane that the traditional transducer. Otherwise, the SideVü signal may be obstructed.
When mounting multiple transducers that provide the same views to the chartplotters the transducers should be set to operate on different frequencies (minimum of 50hz difference between the two transducers). This does not guarantee that the images will be free of interference.
