Reactor™ 40 Autopilot Software Update
Garmin releases software updates regularly to improve performance and correct operational issues for the Reactor 40™ autopilot systems. Performing a software update on Garmin equipment helps maintain the systems and adds new features or functions when available. Software is updated via the marine network through the connected Garmin chartplotter or can be updated using an NMEA 2000® Updater.
Updating Software using a Garmin Chartplotter
  • Garmin chartplotter software updates contain software update information for the entire Garmin system
  • Ensure the NMEA 2000 system connection to the Garmin chartplotter and all the devices included with the Reactor™ 40 autopilot
  • Perform a software update using the Garmin chartplotter
    • See to find the Software compatible with the Garmin chartplotter
See to find the Software for the Garmin chartplotter series. Ensure all devices associated with the Reactor™ 40 autopilot are operational and powered to receive the software update.
Updating Software using the NMEA 2000 Network Updater
Update the Software by using the NMEA 2000 Network Updater. See NMEA 2000 Network Updater. For more information on using the NMEA 2000 updater See Using the Garmin NMEA 2000 Network Updater.
NOTE:  If using an NMEA 2000® Network Updater with a software version below 2.1, update the NMEA 2000 Network Updater before trying to update the Autopilot system software. See Using the Garmin NMEA 2000 Network Updater and select the dropdown "Preparing the NMEA 2000® Network Updater."
NOTE: The ActiveCaptain® app cannot be used with the NMEA 2000® Network Updater.
Select the applicable Garmin chartplotter below to see the software bundles:
Related
