XMap 8 Will Not Connect To LocalDB Server
If you are not able to connect to a server after installing XMap® 8 desktop software use the instructions below to manually create a server in the installation of SQL LocalDB.
Note: XMap Software has been discontinued. Support is now provided through documentation in the Support Center. XMap data format has not.
Creating a Server on LocalDB
- In Windows 8 type cmd.exe from the Start screen and press Enter.
Note: If using Windows 7 click Start, type cmd in the search field, and press Enter.
- In the Command Prompt window type cd C:\Program Files\Microsoft SQL Server\110\Tools\Binn. Carefully verify each character is entered correctly and press Enter.
- Type sqllocaldb.exe c "xmap8", carefully verify each character is entered correctly and press Enter. After a short wait a message will appear confirming the creation of the XMap8 instance of LocalDB.
- Close the Command Prompt window and attempt to connect to the server in XMap 8 software.
