To Prepare the Blank SD Card or USB Flash Drive:
1. Insert blank SD Card or USB Flash Drive into your computer
2. Open the blank SD card or USB Flash Drive on your computer
3. Create a folder and name it Garmin on the blank SD card or USB Flash Drive
4. Double-click the Garmin folder to open it
5. Create a second folder within the Garmin folder and name it POI
Use Garmin POI Loader to load the custom POIs to the SD card or USB Flash Drive once it has been prepared. See Points of Interest (POI) Loader for more info.
To Load the Files Using Garmin POI Loader:
1. Open Garmin POI Loader
2. Click Next
3. Click Computer as your Save Option
4. Click Next
5. Click Browse and select the location of the newly created POI folder from the above steps
6. Click Next
7. Click Browse to locate and select the folder containing your custom POI file
8. Name the newly created custom POI file "POI"
9. Leave the other two options at their default settings
10. Click Next
11. Click Finish
12. Safely eject the SD Card or USB Flash Drive from your computer before disconnecting it
After loading the custom POI files to the SD Card or USB Flash Drive, they will need to be added to the Kenwood Device.
