BC 20 Wireless Backup Camera
The BC 20 Wireless Backup Camera integrates seamlessly with a compatible navigation device to display video signal.
Installation instructions are included with the BC 20, however Garmin strongly recommends professional installation. If the BC 20 gets power from the vehicle's reverse lamps, the compatible device will automatically display the video feed while the vehicle is in reverse. If the BC 20 is instead connected to a steady power source, the video mode will need to be manually switched on the device by touching the camera button on the main menu or the View Map screen.
The backup camera transmits wirelessly up to 45 feet to the mounting bracket packaged with the BC 20 Wireless Backup Camera. An extension cable can be purchased here if your vehicle is longer than 45 feet. The mounting bracket originally packaged with the compatible Garmin device only supports wired video signal from third-party backup cameras.
The Garmin Learning Center has also created a video series detailing the installation of the BC 20. To watch this video series visit the BC 20 Videos tab.
