Add or Delete Aircraft in eAPIS on FltPlan.com
To Set Up an Aircraft for Use with the FltPlan eAPIS System:
  1. Log in to FltPlan.com.
  2. From the Main Menu page,
  3. Select Premium Services (left side of the page).
  4. Select the eAPIS link or select eAPIS under Favorites.
  5. Under the Add NEW entry or MODIFY existing data section, select the drop-down box labeled Aircraft & Owner Info:
  6. Use New Entry.
  7. Select GO.
  8. Enter the data for your new aircraft.
To Delete an Aircraft:
  2. Select Premium Services.
  3. Select the eAPIS link.
  4. Under Aircraft & Owner Info: select your aircraft from the drop-down list.
  5. Select GO.
  6. Scroll to the bottom and check the box Delete This Aircraft/Owner.
  7. Select Save Aircraft/Owner to save the changes.
Related
