Amplifier Level Setting Guide
Note: The following article describes the Amplifier Level Setting process for most car audio amplifiers, regardless of brand. Specific target voltages for applicable JL Audio amplifiers are included in charts below.
Use these links to learn about the unique process specifically for:
Following the directions below will allow the user to adjust the input sensitivity (or "gain") of the amplifier(s) simply and easily in just a few minutes using equipment which is commonly available in installation bays. Properly setting levels according to this procedure will result in optimum amplifier performance and will also improve system reliability.
Necessary Equipment
AC Voltmeter (Digital display recommended)
CD or file with a sine-wave test tone recorded at 0dB reference level in the frequency range to be amplified (for example: 50 Hz for subwoofer channels, 1 kHz for a midrange application).
Do not use attenuated test tones (–10dB, –20dB, etc.).
The Nine-Step Procedure
Disconnect the speaker(s) from the amplifier.
Turn off all processing on the source unit and the amplifier (bass/treble, loudness, EQ, etc.).
Turn the input sensitivity control on the amplifier all the way down. If there is a sensitivity range switch, set it to the “low” position.
Set the source unit volume to 3/4 of full volume. This will allow for reasonable gain overlap with moderate clipping at full volume.
Using the chart below, determine the target voltage for input sensitivity adjustment according to the nominal impedance of the speaker system connected to the amplifier outputs.
Verify that you disconnected the speakers before proceeding. Play a track with an appropriate sine wave (within the frequency range to be amplified) at 3/4 source unit volume.
Connect the AC voltmeter to the speaker output of the amplifier. Make sure to measure the voltage at the correct connectors (+ and -).
Increase the input sensitivity control until the desired voltage (determined in Step 5) is delivered. If multiple subwoofer amps are being used, set each one to the same exact voltage and you have also level matched them. On a “Slash v3”, HD or XDv2 series amplifier, if excessive voltage is read with the control at minimum (full counterclockwise), switch the “Input Voltage” to “High” and re-adjust.
Once you have adjusted each amp to its maximum unclipped output level, turn down the volume of the head unit and turn it off. Reconnect all the speakers, turn the head unit on and proceed to adjust the level balance between the subwoofer and satellite amplifiers. This is accomplished by listening to the system at a moderate level and turning down the input sensitivity controls of amplifiers that are playing too loudly. Do not increase the input sensitivity of any amplifier as this will defeat the purpose of this procedure by permitting excessive clipping (distortion).
MX Amplifiers Voltage Chart
Imp. | MX280/4 | MX500/4 | MX600/3 | MX300/1 | MX500/1 | ||||
Ea. Ch. | Bridged | Ea. Ch. | Bridged | Ea. Ch. | Bridged | Sub | Mono | Mono | |
4Ω | 14.1 | 23.7 | 16.7 | 31.6 | 17.3 | 28.3 | 31.6 | 25.3 | 34.6 |
3Ω | - | N/R | - | N/R | - | N/R | 30.0 | 25.7 | 34.6 |
2Ω | 11.8 | N/R | 15.8 | N/R | 14.1 | N/R | 28.3 | 24.5 | 31.6 |
JX Amplifiers Voltage Chart
Imp. | JX400/4D | JX250/1D | JX500/1D | JX1000/1D | |
Ea. Ch. | Bridged | Mono | Mono | Mono | |
8Ω | - | 34.6 | - | - | - |
4Ω | 17.3 | 28.2 | 25.3 | 34.6 | 44.7 |
3Ω | 16.2 | N/R | 24.5 | 35.5 | 47.4 |
2Ω | 14.1 | N/R | 22.4 | 31.6 | 44.7 |
Discontinued JX Amplifiers:
Imp. | JX360/2 | JX360/4 | ||
Ea. Ch. | Bridged | Ea. Ch. | Bridged | |
8Ω | - | 42.0 | - | 33.5 |
4Ω | 21.0 | 38.0 | 16.7 | 26.8 |
3Ω | 20.9 | N/R | 15.5 | N/R |
2Ω | 19.0 | N/R | 13.4 | N/R |
XD (M-Series) Amplifiers Voltage Charts:
System Amplifiers:
Imp. | XD500/3v2 | XD700/5v2 | XD1000/5v2 | |||||
1&2 | Sub | Ea. Ch. | Bridged | Sub | Ea. Ch. | Bridged | Sub | |
8Ω | - | - | - | 34.6 | - | - | 34.6 | - |
4Ω | 17.3 | 26.8 | 17.3 | 28.2 | 26.8 | 17.3 | 28.2 | 40.0 |
3Ω | 16.2 | 26.8 | 16.2 | N/R | 26.8 | 16.2 | N/R | 38.7 |
2Ω | 14.1 | 24.5 | 14.1 | N/R | 24.5 | 14.1 | N/R | 34.6 |
Multi-Channel Amplifiers:
(XD200/2v2, XD400/4v2, XD600/6v2, XD800/8v2)
Imp. | Ea. Ch. | Bridged |
8Ω | - | 34.6 |
4Ω | 17.3 | 28.2 |
2Ω | 14.1 | N/R |
Mono Amplifiers
Imp. | XD300/1v2 | XD600/1v2 | XD1000/1v2 |
4Ω | 28.3 | 40.0 | 49.0 |
3Ω | 27.4 | 38.7 | 49.0 |
2Ω | 24.5 | 34.6 | 44.7 |
Slash v3 Amplifiers Voltage Chart
Imp. | 300/4v3 | 600/1v3 | 1200/1v3 | |
Ea. Ch. | Bridged | Mono | Mono | |
4Ω | 17.3 | 24.4 | 49.0 | 69.3 |
3Ω | 15.0 | 21.4 | 42.4 | 60.0 |
2Ω | 12.2 | N/R | 34.6 | 49.0 |
1.5Ω | 10.6 | N/R | 30.0 | 42.4 |
HD (MHD-Series) Amplifiers Voltage Chart
Imp. | HD600/4 | HD900/5 | HD750/1 | HD1200/1 | |||
Ea. Ch. | Bridged | Ea. Ch. | Bridged | Mono | Mono | Mono | |
8Ω | - | 49.0 | - | 40.0 | - | - | - |
4Ω | 24.5 | 34.6 | 20.0 | 24.4 | 44.7 | 54.8 | 69.3 |
3Ω | 21.2 | 30.0 | 15.0 | 21.2 | 38.7 | 47.4 | 60.0 |
2Ω | 17.3 | N/R | 12.2 | N/R | 31.6 | 38.7 | 49.0 |
1.5Ω | 15.0 | N/R | 10.6 | N/R | 27.4 | 33.5 | 42.4 |
• Voltage_Chart.pdf (3 MB)
• 09 Sine Wave 50hz.wav (10 MB)
• 11 Sine Wave 1khz.wav (10 MB)
