Creating Hybrid Maps in XMap
By default, all raster images appear at the top layer on the map, covering up any underlying data. You can layer any of the DeLorme® map data above the raster imagery using the following instructions.
Note: XMap® Software has been discontinued. Support is now provided through documentation in the Support Center. XMap® data format has not.
- Select the Map Data tab.
- In the Primary Map or Secondary Map, find the category of imagery you want to modify; for example, Color Aerial Imagery.
- Click the + button next to the image category.
- Click the + button next to the name of the image.
- Right-click the image file and select Properties.
- Optional
For some types of GeoTIFF and MrSID data, you can select a color to display as transparent (for example, black). To do so, select the Transparent Color check box and select a color, and click OK. The transparent color will show around the imagery.
OR
If you do not want to select a color to display as transparent, make sure the check box is cleared and click Next. - From the Raster data position drop-down list, select the data that you want to appear above the imagery and clickAdd/Change. Then, click Next.
- Set the zoom range for the data and click Next.
- Select the check box for each map to apply the change to and click Finish.
- You may be asked to apply to all imagery of this type. Select either Yes or No.
