Charging an Automotive Device
Garmin recommends always using the power cable packaged with your device or a Garmin-branded AC power charger. Full power will ensure your device gets the best signals from GPS satellites and traffic updates.
NOTES:
- If using a USB-C cable to power the device, a high power USB charger should be used. See Dual Port USB Power Adapter.
- Third-party cables or adapters may not charge the device or put it in the proper state to receive updates.
- The provided vehicle power cable must be used in the vehicle in order for the device to operate and charge the battery simultaneously. The device cannot be charged by a USB cable in the vehicle.
There Are Two Ways to Charge your Automotive Device's Internal Battery:
Charging Options
Use the High-Current Power Cable which came with your device (Tread® SxS Edition and Tread® 2 - SxS Edition GPS navigators). Use the 12 Volt Vehicle Power Cable which came with your device (Tread® Overland Edition, Tread® XL - Overland Edition, and Tread® 2 - Overland Edition GPS navigators).
| Use a Garmin-branded AC power adapter accessory, such as a wall power adapter.
NOTE: Place the unit screen side down when charging to reduce stress on the device's USB port. |
High-Current Power Cable 12 Volt Vehicle Power Cable |
Temperature can affect the charging of a device. The battery won't charge if it registers a temperature of 0°C (32°F) and below or 45°C (113°F) and above. See Charging Factors for an Automotive Device for more information about the effects of temperature on your device
The battery will not drain when an automotive device is connected to external power.
See How Can I Tell Whether My Automotive Device is Charging? to ensure your device is charging properly.
Your device will be placed into Standby mode when the power button is pressed and released. Fully power off the device before storing it to preserve the charge on the battery. Press and hold the power button for 5 seconds. Then touch Off.
A Garmin AC adapter or replacement cable can be purchased at Garmin’s online store.
