(2020) Service Bulletin 20103 Rev A: G1000 NXi System Software Version 3643.04 for G1000 NXi-equipped Embraer EMB-500 Phenom 100 airplanes
PRODUCTS AFFECTED:
G1000 NXi-equipped Embraer EMB-500 Phenom 100 aircraft with system software version 3643.00 or 3643.01 installed under STC SA01933WI are affected.
NOTE
This STC Service Bulletin supersedes Garmin STC Service Bulletin 2091.
CERTIFICATION AUTHORIZATION:
STC SA01933WI
COMPLIANCE:
MANDATORY: Compliance with the STC service bulletin is mandatory at the next 100-hour/annual inspection, not to exceed 6 months.
PURPOSE:
This Service Bulletin announces the approval of G1000 NXi System Software Version 3643.04 in Embraer EMB-500 Phenom 100.
G1000 NXi System Software Version 3643.04 provides the following enhancements:
  • Corrects SW loading of the GWX 68 Weather Radar
  • Corrects the EDM (Emergency Descent Mode) annunciation color from red to green
  • Enables the CVR (Cockpit Voice Recorder) erase function
  • Enables the CVR failure indication
  • Enables the FDR (Flight Data Recorder) failure indication
  • Enables the cabin altitude high driven automatic thrust reserve inhibit
