Garmin Pedal Power Meter Calibration Error Codes
The following error codes may be displayed during the calibration of Rally and Vector 3 Power Meter pedals. A code value can be a combination of two error codes added together. See the meaning along with the corrective action for each error code to solve any issue you are having during calibration:
NOTE: Do not use Pedal Extenders as they may cause calibration issues in addition to damage to the pedals.
CodeMeaningCorrective Action
1Calibration in Progress on left pedalCalibration already in progress
2Calibration timeout on left pedalMake sure pedals are stationary and under no load
3Calibration failure due to failed upright check on left pedalPosition bike in an upright position
4Calibration aborted due to pedalingMake sure pedals are awake by spinning the crank and try again
8Calibration request could not be sent to right pedal
16Calibration request was sent to the right pedal but no response was received
32Calibration failure due to failed upright check on left pedalPosition bike in an upright position
64Installation angle parameters not recognized on left pedalMake sure pedals are awake by spinning the crank and try again
128Installation angle parameters timeout on left pedal
256Calibration in Progress on right pedal Calibration already in progress
257Calibration in Progress
258Calibration aborted due to pedaling on both pedals in progressMake sure pedals are stationary, awake, in an upright position and under no load
259Calibration failure due to failed upright check on left and right pedal in progress
260Calibration timeout on left pedal and right pedal in progress
512Calibration timeout on right pedalMake sure pedals are awake by spinning the crank and try again
513Calibration aborted due to pedaling on both pedals in progressMake sure pedals are stationary, awake, in an upright position and under no load
514Calibration aborted due to pedalingMake sure pedals are stationary and under no load
515Calibration failure due to failed upright check on right pedal and left pedal in progressMake sure pedals are stationary, awake, in an upright position and under no load
516Calibration timeout on right pedal and left pedal in progress
768Calibration failure due to failed upright check on right pedalPosition bike in an upright position
769Calibration failure due to failed upright check on right pedal and in progress on left pedalMake sure pedals are stationary, awake, in an upright position and under no load
770Calibration failure due to failed upright check on right pedal and pedaling on left pedal
771Calibration failure due to failed upright checkPosition bike in an upright position
772Calibration timeout on right pedal and failed upright check on left pedalMake sure pedals are stationary, awake, in an upright position and under no load
1024
Calibration aborted due to pedaling on right pedal
1025Calibration timeout on right pedal and in progress on left pedalMake sure pedals are stationary, awake, in an upright position and under no load
1026Calibration timeout on right pedal and pedaling on left pedal
1027Calibration timeout on right pedal and failed upright check on left pedal
1028Calibration timeoutMake sure pedals are awake by spinning the crank and try again
4096Calibration failure due to failed upright check on right pedalPosition bike in an upright position
8192Installation angle parameters not recognized on right pedalMake sure pedals are awake by spinning the crank and try again
16384Installation angle parameters timeout on right pedalMake sure pedals are awake by spinning the crank and try again
Related
